Build List
LEAD Lathe
zero z mongrel
long overdue overhaul of 1000 x 1000 machine
Gerber 404 Retrofit
Not sure if the Blackbox X32 is the right option here, just looking for guidance.
Rotary Axis OX Derivitive
A Rotary Axis CNC router based on the OX CNC Router
Dragon Plasma cutter
Build Author Scott Drake Views 13860
1500x1000 CNC Router
Build Author OpenBuilds Views 17206
BlackBox X32
The next level of CNC motion control solutions. Packed with advanced new features and built on the reliability of the proven BlackBox system
Build Author Elias Ramburger Views 516
600 volume 3D-Printer
2 GANTRY CNC HOTWIRE MACHINE
A 2 independent gantry affordable hotwire machine.
Build Author jaron kennell Views 3953
Rezo 1390 100W CO2 Laser
Sphinx 66
Build Author Neil Rosenberg Views 34961
Build Author Retsaj Views 50856
Build Author Michael.M Views 35282
7050 Sphinx
My Lead 1010
C-beam Machine - Modesty
Build Author Joe Young Views 10850
Rack and Pinion (Death to Belts)
Low profile rack and pinion linear actuator design
Build Author Quentin Karmark Views 5442
Laguna Swift 4X4 CNC mill retrofitted with OpenBuilds
Used Laguna Swift 4X4 CNC mill with Water-cooled Spindle and RichAuto serial pendant retrofitted with OpenBuilds/Blackbox/Interface
Techsoft Roland TS-30 rebuild
Openbuilds 4x8 cnc
Build Author Mark Carew Views 18591
Build Author OpenBuilds Views 22247
INTERFACE CNC Touch Control System
Super cool standalone Human-Machine Interface for controlling your CNC machines!
Build Author StrictlyScale Views 6401
Lead1010 Build with Enclosure
First time CNC builder puts together a Lead1010 machine.
Build Author EvanH Views 801
Build Author Keith Davis Views 19482
Vulcan MAX
5'x10' CNC Plasma/Mill Table
Plasma Mill CNC
Build Author Bob Darrow Views 6069
BA3DP
modifying ACRO
"Hirata scrap find" CNC
First CNC and first attempt at building one also, so yeah... good luck to me!
Z Floating Head
KRE CO2 2x4 Laser
Large Format CO2 Laser Cutter
Build Author Mark Carew Views 73201
Build Author Mark Carew Views 57153
Build Author Kyo Views 21887
Sphinx 55
Build Author cdsmith12 Views 24166
Build Author openhardwarecoza Views 71083
openBuilds FreeBURN-1 V-slot CO2 Laser (60-100w)
DIY Lasercutter: Budget orientated, medium sized (60-100w), safety first, based on Lasersaur software toolchain
Build Author Spark Concepts Views 13125
CNC xPRO V4
Take your build to the next level with the CNC xPRO V4!
cnc back stop for brake press
back stop build
Build Author Troy Proffitt Views 23518
Hydraulic lifting table
Build Author Mark Carew Views 116755
C-Beam™ Linear Actuator
My large machine 48 X 48
Build Author Frank Del Favero Views 5161
Build Author Mark Carew Views 177877
LEAD CNC 1010 (40" x 40")
Build Author sausagePaws Views 72335
Build Author Ryan Lock Views 122575
WorkBee CNC Machine
Build Author CONUCON Views 2623
3DTwinX Gantry CNC System
Belt driven 3-axis linear system for high precision and low costs. > Threading and linear real cutting needed
Build Author Mark Carew Views 28040
High Z Mod for Lead CNC
LR/BS CNC Router
An easy to source/easy to build, yet quite robust CNC router. This design has not yet be implemented.
Build Author tshilling Views 31427
Build Author Mac6986 Views 14949
Build Author Ryan Lock Views 128895
Ooznest OX CNC Machine
Heavy Metal
Build Author Gerald Klein Views 13149
Reworked Sepcraft 420 CK
Its alive !
Build Author Kyo Views 29860
Sphinx 1050
Salmon Sphinx 1.0
Build Author Suhmanda Views 1954
DIY CNC SPINDLE
CNC SPINDLE FOR DIY ROUTERS AND MILLING MACHINES ITSRS-985 MOTOR HAS MUCH BEFINITS THAN ANY OTHER DC MOTOR IN MARKET
Gauthali V2.0 DIY 3D printer
Build Author alan richard Views 45111
Core-XY Cube
Build Author Rob Taylor Views 15487
M4: 1510SS Heavy Mk.I
Build Author Keith Davis Views 32202
OneZ i3
TrueUp Bold
Pneumatic cnc cutter with festo drive
CNC Glass cutter
CNC Cutter Knife
CNC knife cutter with loline blades
CNC Linear Slide for DIY project
Low cost cnc linear drive for making any xyz cnc structure
Plasma Table 006
Build Author Mark Carew Views 252036
C-Beam® Machine - Plate Maker
Build Author Mark Carew Views 13179
C-Beam XLarge X/Y Table
Build Author Ryan155 Views 8427
RIGCNC
I made a mill from first principles because I didn't like any of the ones that were out there, More info can be found on the website RigCNC.com
Build Author OpenBuilds Views 12175
C-Beam® Tension XL Linear Actuator
Build Author that-jim Views 6862
Z-Axis Upgrade For My Sphinx
Build Author that-jim Views 41043
Build Author MattR Views 16491
Build Author Damian V-SLOT Poland Views 1755
LEGO BOX
Build Author OpenBuilds Views 18147
OpenBuilds Table Series
The OpenBuilds Table Series offers a modular table structure that grows with your needs.
My ACRO Build
An ACRO laser put together with some repurposed and some new parts.
Build Author Mark Carew Views 68057
OpenBuilds Workbee 1010 (40" x 40")
The OpenBuilds WorkBee 1010 - 1000x1000 Lead Screw Driven CNC Machine
A Rolling Plotter
Project Completed.
Build Author UltiBots Views 34104
UltiBots CB3030 CNC Router
Build Author Yanou Fishel Views 7991
Beefed up Minimill
C-Beam Machine XLarge
A rigid and wide format, plate and carving CNC.
Build Author Sigifredo Cruz Rojas Views 2531
ALl included interface
Build Author 2SIsurf Views 4210
Hotwire cnc Surfboards
Xl 2 axis foam cutter Eps Surfboard blanks Simple open concept but high production machine. Shape 3d case with open builds controller
Simpl3rBot
A framing design for cantilever style printers
Build Author Jason Moore Views 9868
Lead1500 Plasma Table w/THC
Denford CNC Resurrection
Denford CNC Mill Update
Build Author wackocrash5150 Views 16927
45W CO2 Laser Build
Y-1200 co2 laser
Y-1200 Build The Y-1200 has a cutting area of 1200 x 600mm and the main chassis has a external size of 1620 x 955 x 450mm. The recommended power output is 60-90W, this can also be increased with the use of an extension box. designed by furtherfabrication ROB CHESNEY FREELANCE INDUSTRIAL DESIGNER.
