Build List
Mortiser
A work-in-progress build using OpenBuilds parts to create a mortising jig.
5 x 10 CNC - Sub $3000 - Wall Mountable
I wanted a 5 x 10, Wall mounted CNC, that cost less than $3000. I think Im pretty close.
Build Author
David E. Flores E.
Views
3705
DaveWare DrawBot
Turning my prototypes into real objects, it will be required a great amount of drawings, A LOT. Therefore, against the ink costs raise price push me to think in a way to draw models, blueprints, etc. at very, VERY low cost. This is where my DrawBot was born
Needle cutter for foamplates
Cutting Depron foam panels by an oscillating needle
Build Author
Mark Carew
Views
230654
OpenBuilds ACRO System
The OpenBuilds ACRO System was developed to be the most accurate and cost effective positioning system in its class. The ACRO System incorporates the OpenBuilds V-Slot system and, therefore, has the unique ability to expand to multiple sizes creating a size configuration custom to your needs. Choose the size that best fits your workshop. This versatile system allows for precise positioning of many different mountable tools and attachments.
Laser Rotary Tool / Attachment
Rotary attachment to engrave cylindrical objects on laser machines
Build Author
Mark Carew
Views
12500
C-Beam® Double Wide Gantry Actuator
This easy to build actuator is configured to have not only strength, but accuracy! This low profile option offers endless possibilities, and we cant wait to see how this actuator is implemented in your build ideas!
Build Author
Mark Carew
Views
208201
LEAD CNC 1010 (40" x 40")
Build Author
Rick 2.0
Views
18521
C-Beam Mini Mite
A small system with a big bite. Design achieves a good balance between machine size vs. build area, rigidity and ease of construction all while keeping build cost as low as possible.
Build Author
BCulbertson
Views
2560
Lead 1515 with Upgrades
My upgraded OpenBuilds Lead 1515
Gerber 404 Retrofit
Not sure if the Blackbox X32 is the right option here, just looking for guidance.
Dragon Plasma cutter
Build Author
Retsaj
Views
68070
Build Author
hbtousa
Views
1235
Six_Axis Camera Slider
X is 1000mm, Y is 1500 mm, Z is 1000mm. It Rotates 360 degrees and Tilt also can move 360 degrees. I also have a motor that controls the focus of the camera.
Build Author
sausagePaws
Views
77842
Build Author
OpenBuilds
Views
5001
Multi Z LEAD Machine Addon
The Multi Z adds multiple Z axis to a LEAD CNC Machine allowing it to cut and carve 2 to 3 times the amount of projects in the tame it takes to make just one
Build Author
cdsmith12
Views
38566
Build Author
Mark Carew
Views
106167
V-Slot® NEMA 17 Linear Actuator Bundle (Lead Screw)
Example model of lead screw driven actuators for your next project!
Build Author
Mark Carew
Views
62703
Build Author
Elias Ramburger
Views
4967
600 volume 3D-Printer "ABEA"
Build Author
robert christensen
Views
869
Tool holder
I saw a video of some one pouring resin in a mold,so i did a little research, i bought some resin,and some molds and magnets all from Amazon, it took me several tries and a big mess but it finally finished. The first pour i poured a small batch to make a templet,i marked all the holes that needed drilling then i marked the underside of the mold where i wanted the magnets, next was making the pcs i needed
Plexi Panel
Plexi Panel to use for a vfd test enclosure. The box will be wall-mounted on plywood, so the back of the box is not necessary. - The bottom of the box is not necessary because the box will be fixed on concrete on the floor. On the door, I was thinking of putting 4 brackets instead of two. We'll have two 21” doors
Just Another CNC
I wanted to make my own unit. I enjoy building and was looking for a challenge.
K40 upgrades
Cheap chinese K40 laser upgrades, including 60x30cm working area, MKS or SKR controllerboard (smoothieware or marlin, not yet decided.) Light, psu and a bit more :)
Workbee 1010 et laser atomstack M100
Je ne sais pas comment brancher mon laser sur la blackbox?
Z Floating Head
Build Author
Scott Drake
Views
23988
1500x1000 CNC Router
Time Lapse Camera Slider
This is my first go at building a simple Time lapse camera rail system using as much pre-existing hardware and software as I could.
CNC accessory box Made 100 % from recovery materials
Quick construction. A few pieces of wood recovered in the trash can, two hooks one hinge, a few screws and a little glue. [Edit] Added the SVG file for sharing (I forgot it)
Dream to practical
This is my journey from a dream machine to a practical (for me) machine. This is a Cartesian style frame that can change tool heads quickly. The first version will have milling and 3D printing tool heads. Later on I'll add a drag knife tool head.
Build Author
OpenBuilds
Views
28510
BlackBox X32
The next level of CNC motion control solutions. Packed with advanced new features and built on the reliability of the proven BlackBox system
Pro Light 1000 CNC Machining Center Rebuild
Replacing the Pro Light control box with a Open Builds BlackBox.
Build Author
OpenBuilds
Views
4165
A1 ACRO Draw Bot
We created an A1 ACRO Drawing robot specifically for the artist communities. It utilizes the popular ISO 'A series' paper sizes standards
Pen Plotter
All metal A3 CoreXY pen plotter
Build Author
Neil Rosenberg
Views
40266
Build Author
Frank Del Favero
Views
8716
Edge Carve MK1
I have created a video showing the Edger Carve features https://www.youtube.com/watch?v=v5mV_6vyxAA&t=3s
Build Author
Troy Joachim
Views
17994
Sigron IDEX
BNC3D Signax + Voron = Sigron IDEX
Build Author
Mark Carew
Views
265436
C-Beam® Machine - Plate Maker
Build Author
Alexander_Bulgaria
Views
972
CNC milling machine,lathe,gantry,fdm,clay 3d printer ALL IN ONE
That is the only cnc you will need for most of your diy projects.
cnc back stop for brake press
back stop build
XYZ Factory Bot
Very large format build platform designed really for printing multiple items in one session ether all the same or different. Longer term I would like to have multiple X axis on the Y axis rail. bit of a slicer challenge though.
OpenBuilds ACRO Z Axis
Z-Axis for OpenBuilds ACRO system. It is sturdy enough to carry a small drill.
KRE CO2 2x4 Laser
Large Format CO2 Laser Cutter
Fixed Gantry CNC Router
A fixed gantry router using OpenBuilds control and electronics.
LEAD 1010 PLASMA Add-On
LEAD 1010 PLASMA Add-On is a great modification you can do for your LEAD 1010 to convert it into a metal cutting monster machine!
Build Author
David E. Flores E.
Views
2323
F-Ender-Plus 3D Printer
F-Ender-Plus its based on the Ender 3 Pro, but improved: CR-10 hotend, double gear extruder, double z-axis motor, bltouch incorporated, hotbed leveling improved strings kit. Most made using local vendor parts, and still I'm increasing my knowledge of how get better 3D printings by calibrating motors steps, leveling the hotbed and z-axis; using a 3mm thick glass...
Absolute positioning hardware and software
Absolute linear positioning using deBruijn sequences.
Build Author
David E. Flores E.
Views
5849
ACRO System w/Laser 80W
This is my version of the OpenBuilds ACRO System CNC, a 1010 version (1000mm x 1000mm). I need this machine to build PCB prototypes within 2-days at maximum. I will try to build PCBs using drill and laser methods...
Hot Wire 4 Axis CNC Foam cutter
This build uses drawer slides and thread rod to create foam wings and fuselages by passing a hot wire through the foam which makes very accurate shapes. I built a Radio Controlled SuperVC10 using foam but did have a cnc machine then so I had to make many templates to guide the hot wire. This inspired me to build a cnc hot wire cutter. Works really well and have made several RC models with it now
Build Author
Jacob Lotter
Views
25806
1510 Workbee Modified
Some of the things that I have done to my 1510 Workbee Installed Linear rails and bearing blocks with drawings. Installed Ops console Made conversion plates for extruded aluminum to casters Extended z axis travel by a couple inches with steel plates. As of now in the process of installing Lead screws across the 1500mm length.
Build Author
Mark Carew
Views
16609
NEMA 17 Belt and Pinion Actuator
This Belt and Pinion actuator is a great example of how easy it is to convert your machine into a belt drive system.
Build Author
Mark Carew
Views
24610
Build Author
Mark Carew
Views
17439
Nema 23 Belt and Pinion Actuator
This easy to build and effective system can take your builds to the next level! This design is strong and accurate and could be the solution/upgrade that you've been looking for!
Automated Media Blaster
Automated Media blaster retrofit.
Build Author
OpenBuilds
Views
25688
OpenBuilds Table Series
The OpenBuilds Table Series offers a modular table structure that grows with your needs.
Build Author
cnc-trucker
Views
2800
Arduino Mega to EMC2 (LinuxCNC) Plasma Table Conversion
This is a story about a guy who started with a $25 set of plans, and through 4 iterations/ rebuilds, ended up with a professional quality CNC plasma table capable of cutting anything steel up to 2 inches thick.
5'x10' CNC Plasma/Mill Table
Plasma Mill CNC
Project Completed.
Techsoft Roland TS-30 rebuild
LEAD Lathe
Build Author
Keith Davis
Views
24673
Vulcan MAX
Openbuilds 4x8 cnc
Small Desktop CNC Router/Mill
I designed and made this from scratch. The frame is welded steel filled with sand, and most of the other parts are aluminium. It's controlled with a DIY ESP32 controller running GRBL_ESP32
Build Author
OpenBuilds
Views
32566
OpenBuilds Enclosure Series
Easy to build series of enclosures for all your CNC needs!
A Rolling Plotter
zero z mongrel
long overdue overhaul of 1000 x 1000 machine
Rotary Axis OX Derivitive
A Rotary Axis CNC router based on the OX CNC Router
2 GANTRY CNC HOTWIRE MACHINE
A 2 independent gantry affordable hotwire machine.
Build Author
jaron kennell
Views
9062
Rezo 1390 100W CO2 Laser
Sphinx 66
Build Author
Michael.M
Views
43355
7050 Sphinx
My Lead 1010
C-beam Machine - Modesty
Build Author
Joe Young
Views
13960
Rack and Pinion (Death to Belts)
Low profile rack and pinion linear actuator design
Build Author
Quentin Karmark
Views
8410
Laguna Swift 4X4 CNC mill retrofitted with OpenBuilds
Used Laguna Swift 4X4 CNC mill with Water-cooled Spindle and RichAuto serial pendant retrofitted with OpenBuilds/Blackbox/Interface
Build Author
OpenBuilds
Views
27800
INTERFACE CNC Touch Control System
Super cool standalone Human-Machine Interface for controlling your CNC machines!
Build Author
StrictlyScale
Views
9467
Lead1010 Build with Enclosure
First time CNC builder puts together a Lead1010 machine.
Build Author
EvanH
Views
3870
Build Author
Bob Darrow
Views
9191
BA3DP
modifying ACRO
"Hirata scrap find" CNC
First CNC and first attempt at building one also, so yeah... good luck to me!
Build Author
Mark Carew
Views
85090
Build Author
Kyo
Views
27268
Sphinx 55
Build Author
openhardwarecoza
Views
76119
openBuilds FreeBURN-1 V-slot CO2 Laser (60-100w)
DIY Lasercutter: Budget orientated, medium sized (60-100w), safety first, based on Lasersaur software toolchain
Build Author
Spark Concepts
Views
15652
CNC xPRO V4
Take your build to the next level with the CNC xPRO V4!
Build Author
Troy Proffitt
Views
27782
Hydraulic lifting table
Build Author
Mark Carew
Views
124354
C-Beam™ Linear Actuator
My large machine 48 X 48
Build Author
Ryan Lock
Views
139027
WorkBee CNC Machine
Build Author
CONUCON
Views
5806
3DTwinX Gantry CNC System
Belt driven 3-axis linear system for high precision and low costs. > Threading and linear real cutting needed
Build Author
Mark Carew
Views
58761
High Z Mod for Lead CNC
