FARM OX (Four Axis Rotary Machine)
Discussion in 'CNC Lathes' started by ymilord, Jul 29, 2015.
  1. Ronald van Arkel
    Very nice design! :eek: I love how you are building it around the BeagleBone Black and LinuxCNC (MachineKit). Finally some one that has the balls to go off the known path! :D
    Thank you for sharing and keep up the good work!
    -Ronald
    silopolis likes this.
  2. john harvey
    this build is fantastic
    I am really looking forward to its completion.
    I have a number of projects that I can see I will be able to do with something like this
  3. ymilord
    ymilord Journeyman
    I've been running the FARM Controller (BBB /w MachineKit) on my main CNC (It's another brand that starts with a S and ends with a Oko...) for about 3 days. Runs sweet. I've added all the bells and whistles for the advance players and a simple GUI for the new ones. But believe me the Advance players are going to love the extra features. For example-
    Quick Edit, The push notifications will show Job start (M197) Job Completion (M198) and Tool Changes (M199).
    #33 ymilord, Sep 1, 2015
  4. Mark Carew
    This is going to be great @ymilord ! keep up the good work
  5. Joshua Coke
    Great design. I will be building the 5 axis version. Why the BBB system, I ask because I have both the planet-cnc MK3 control and a TinyG that are both able to control a system like this. Is there an advantage to your control?
    #35 Joshua Coke, Sep 4, 2015
  6. ymilord
    ymilord Journeyman
    You can use any motion controller you want. I just prefer LinuxCNC. Alot more options. Touch probing, Fixturing a'la G54, presetting Tool Offsets, Custom M-codes, 3D Digitizing, Localized g-code sending and performance to name a few. Plus the advantage of using any driver package you want with a simple breakout board.
  7. ymilord
    ymilord Journeyman
    Currently waiting for a X2 mini mill to arrive so I can cut the steppers plates out at the thickness I want. This unit already is CNC ready so it just the matter of installing steppers and adding the profile to the FARM Controller.
  8. John Meikrantz
    John Meikrantz Well-Known
    I just started going down the LinuxCNC path, more for education than anything else! I currently have an Ox derivative running Grbl/xPro CNC controller. I have a BBB now with Xylotex BBB_25 parallel port and MachineKit loaded. What did you use for a driver board? Looks like a TB6600 board? Any detail on that hardware?
    Thanks, really enjoying watching this build progress!
    -- John
  9. Dieguito
    Dieguito New
    After a lot of reading, this is my first post, and gotta say, this machine is mind-blowing! I'm coming from 3d printing, but definitely would make an effort to get one of these working...
    Eager to see the assembled monster!
  10. bpatterson42
    Looking forward to starting with LinuxCNC on BBB as well. Which driver board is that? Interested about all the bells and whistles too!
    Awesome build!
  11. Dieguito
    Dieguito New
    Well, I decided to take the task and build something similar, I'll go for the 5 axis milling variety... Since I don't have a great deal of experience in CNC, it will probably take many months to accomplish, so your documented progress, ymilord, would greatly make my effort a lot easier...
    So far I've ordered a BBB, the 7.0” TFT LCD CAPE, a DB25, a 5 axis breakout board and stepper drivers and motors. I'm still considering the layout for the 5 axis, and would love to hear other peoples ideas on the subject. What I'd really like to accomplish is something like this http://www.pocketnc.com, the openbuilds way, using c-beams.
    For now, I'm favoring a layout like this for the 5 axis: http://www.aliexpress.com/item/Free...ew-Table-Column-Type-milling/32341244073.html
    I'd like a different design for the trunnion table though, something more along pocket nc's aproach.
    #41 Dieguito, Oct 4, 2015
  12. Patrick Walls
    Hey,
    How's it going? Just curious if there is any updates and or pictures of the build? Really looking forward to what you have going.
    Thank you
    PatrickB
  13. ymilord
    ymilord Journeyman
    Nothing to report for now. A couple life issues has come up. Plus the budget I was using for this build has been moved to something else.
    As soon I get back started again. I'll start posting again.
    raul dela likes this.
  14. stargeezer
    stargeezer Journeyman
    I hope the "life issue" is not too serious and you are allowed to refocus soon. I've been watching this build for a while and look forward to it's completion. We have all been there from time to time. :) Some of us just call it life, but that's my little issue :)
    If you might be so inclined, could you suggest any videos/reading on setting up Linux CNC and connecting the BBB to the rest of the hardware? I've picked up a BBB and a 7" lcd recently with the intent of following your lead on this build. Being software de-clined I need things as simple as possible. Big pics, drawings in crayon and such. :)
  15. mod_extreme
    Good Proyect!
  16. Paul Stoller
    Paul Stoller Journeyman
    Very intriguing, I look forward to seeing how everything turns out.
  17. SamKircher
    So cool, cant wait to see this running!
  18. helwigg
    helwigg New
    Were does this project stand? I hope to see it finished or at least a list of materials and a way to copy what has been done so far?
  19. Marcus Wolschon
    I'm building a similar machine without the C axis.
    Did you experience any stiffness issues with the Z axis twisting around the vertical axis slightly when moving back and forth on the X axis under load?
  20. Mark Carew
  21. Marcus Wolschon
    Here is a photo of the first test cut.
    I'll write a lengthy posting in my blog soon.
  22. Mark Carew
    Hey! that is looking great man. Keep up the good work and I hope that you will share your Build here with the community so that we can all learn to make this.
    Thank you for sharing this cool pic of it in action.
    BTW do you have a name for it?
  23. Marcus Wolschon
    Probably not. Too many places and they ALL want me to do that. So I'll keep posting my stuff in my own Blog.
  24. Marcus Wolschon
    Here you go:
    Tales of a modern life: Building a rotacy CNC milling machine
    Note that this machine is prototyped with Openbuilds assemblies but these will ultimately be replaced by linear guide rails (instead of rollers on eccentric bearing) and ballscrews(instead of ACME screws through plastic blocks) to improve squareness, stiffness and long term performance.
  25. Mark Carew
  26. sutharvj66
    hi, i like this rotary build, and would like to build one, can you please share a parts list inc hardwares, software and controller with wiring diagram?
    thanks a lot in advance.
