OpenBuilds OX CNC Machine
  1. PieterJ
    PieterJ New
    I love this design! I tried to order the parts from your part store, but not all of it can be ordered. The V-Slots and OX Plates will be the most difficult to get here in South Africa. I am really excited, and want one for myself for Christmas. 'The selected product combination is currently unavailable.' ? Do I just wait?
    The best suggestion is to contact the store to find out when the they expect the missing parts to be back in stock. You can either email http://support.openbuilds.com/support/home or use the contact form on the about us page (or both). Alternatively, there are OpenBuilds distributors around the world which may have the parts you are looking for already in stock.
    As for the OX plates, yes you will have to either wait for the store to gets its first production run or you can go with one of the vendors listed at start of this thread.
  3. Williams
    Williams New
    I´m a novice openbuilding engineer and i have a basic question. This question was already made in this forum but with no answer. There are two types of eccentric spacers, 6mm and 1/4" inch, witch are very similar. Witch one may i use in this project? what are the differences between them? height?
  4. asb_79
    asb_79 Well-Known
    @Williams they only differ in length. It probably doesn't really matter which ones you use as long as you are consistent.
    However, since the wheels come with 1/4" Aluminium tube spacers that can be used for the fixed wheels it makes sense (to me) to use 1/4" eccentrics instead of buying new 6mm Aluminum spacers.
  5. Bryant
    Bryant New
    Ok, so I'm building a variant of the OX and I have it all assembled and just discovered that I failed to drop in my t-nuts to secure my X axis belt. Any bright ideas to fix my stupid mistake without taking apart the gantry? Drop in t-nuts appear to be too thick to allow the belt to get under the t-nut.
  6. dddman
    dddman Journeyman
    slide them from the side
  7. Bryant
    Bryant New
    Yeah, I just noticed that some brilliant designer had anticipated this failure and put a nice little cutout in the plate. Saved me a ton of time :)
    On another note, has anyone felt the need to lubricate the leadscrew/delrin nut? If so, what did you use?
  8. dddman
    dddman Journeyman
    No, it will loosen itself enough in a couple of uses
  9. Alberto Boria
    Need help something strange with z axis
    I made a simple square with 2 circles inside. When I start to cut the first circle cut fine but when moves up and go to cut the second circle the z axis goes all way down and had to stop it to prevent damage. I'm using cut 2d with the shapeoko post processor in Grbl. The gcode looks right on note pad but keep doing the same thing. Any ideas what's wrong with this.
    Regards,
    Alberto
  10. Tweakie
    Tweakie OpenBuilds Team
    Moderator
    Just a guess, but it could be that your acceleration and velocity settings for the Z axis are too high resulting in a loss of steps when the axis is raised thus cutting too deep when the Z axis returns down.
    Tweakie.
  11. planga
    planga New
    Quick question: If you intend to use a Nema 23 for the Z axis, do you need 2 of the new Nema 23 threaded rod plates (new item from the OpenBuilds parts store), or 1 normal (Nema 17) threaded rod plate and 1 Nema 23 threaded rod plate?
    Thanks.
  12. Brayden DeVito
    Would someone be so kind as to post their GRBL settings on here? (0.9)
    I've used everything listed in the Openbuilds store.
    Using the settings KRAM gave as a starting point seem to be giving me problems.
    I'm just curious to see what everyone else is getting for STEP/MM travel etc...
    thank you so much!
    PS.... changing feedrate (G01 FXXX) does not seems to change anything at all on my X and Y axis....
    help!
    Brayden
  13. dddman
    dddman Journeyman
    One would be enough
  14. Bent Wing Bandit
    Being a newbie to this CNC thing, I too can't wait to get started on this build. My experience is in the computer and printer world so most of this will not be too hard. The applications though, will be something to study to see what file types can be converted to other types and then to the g-code needed to feed to the CNC. Discovered Sketchup so that is a start. Converting PDF to a cad file is not working so well. Thought , at first, that a kit would be nice but I found the parts list so that will do nicely. I wonder if this can be scaled out to cut on 4' X 8' sheets for cutting out parts to build a dresser or any such larger project?
  15. Nugz
    Nugz New
    You only need one to mount the Nema 23 to the Z-axis. You can use the Nema 17 plate on the bottom, or if you prefer for aesthetic reasons, you can use a Nema 23 plate there also.
    -Nugz
  16. snokid
    snokid Journeyman
    ok read thru most of the posts and can't find the answer.
    I need a power supply
    I'm looking at 24v but how many amps? is 10 enough?
    thanks Bob
  17. Hytech2k
    Hytech2k Veteran
    24v is fine, amps depend on the motors you want to use and how many, Nema 23's usually draw about 3.5A each, and according to the parts store looks like 17's take about 1.68 A/Phase. Figure out what motors you want to use and how many then multiply the amps rating to get an idea of what size PW supply. Some people run the on less than what the total amps required is and they work just fine... For me I err on the side of more can't hurt.
  18. snokid
    snokid Journeyman
    Ok thank you looks like 15 - 20 should do it.
    Bob
  19. Jeremy Young
    Hi Guys,
    So after about 10 hours work I have got my Ox mostly together and wanted to test out the electronics.
    I am relatively familiar with the mechanical side of things but am a novice with electronics.
    Is anyone here using the xPro board from Spark Concepts?? I have the new V2 model and it came with absolutely no documentation. Does anyone know where I can find some setup guidelines?
    After a long while I managed to find some drivers from a random website and got it connected to my computer via Universal G-Code Sender. It seems to be moving the Z axis nicely but I would be interested in seeing how others are configuring/setting up this controller with the Ox.
    J
  20. GrayUK
    Do a search for XPro, or Spark, or Michael in the members list. He's one of the guys who made it.
    Gray
  21. oni305
    oni305 Well-Known
    Hi,
    it would be nice if there was a PDF file with the measures (metric) of the OX plates, to get ideas for creating new designs for new types of machines ( laser, foam cutter, ecc... )
  22. Nugz
    Nugz New
    @Jeremy Young
    This should get you going Jeremy:
    https://github.com/Spark-Concepts/xPRO/wiki
    https://github.com/Spark-Concepts/xPRO/blob/master/CNC xPRO QUICK START GUIDE V2.pdf?raw=true
    http://www.openbuilds.com/builds/cnc-xpro-driver.643/
    http://openbuildspartstore.com/blog/tag/xPRO
    -Nugz
  23. John Meikrantz
    John Meikrantz Well-Known
    Two questions:
    Self tapping screws:
    I am just about to begin my Ox build - UPS came today! Have a question about the self tapping screws. Any caveats? Once threads are cut, can the screws be removed and reinserted?
    Limit switches:
    Are snap action switches preferred? Not sure of any issues with hysteresis with open/close.
    Thanks!
    JohnM
  24. Tweakie
    Moderator
    Hi John,
    Yes, self tappers can be removed and re-inserted. When re-inserting, with a bit of care (turn anticlock until you feel the indent then turn clockwise) they can be fitted back into the same thread they made first time.
    Switches have 'contact bounce' more so when closing so it is considered preferable to use 'normally closed' contacts which open when the limit is reached. Perhaps take a bit of time to read Electronics101 - it may be helpful to you. http://openbuilds.com/threads/electronics-101.693/
    Tweakie.
  25. Hytech2k
    Hytech2k Veteran
    Also some CAM software have an anti bounce built in, might want to check into your software settings. I use Mach 3 and there is a setting to compensate for bounce, I use proximity sensors so it's not much of a problem but from what I gather micro switches are more prone to suffer from bounce.
  26. John Meikrantz
    Thanks for the helpful link! I didn't know if there was any difference between "snap action" and non. Seems like snap action switches would be less prone to contact bounce.
    John
  27. Jeremy Young
    Hi @Nugz thanks for your reply. I have previously been through most of those links and saw nothing about having to load drivers. I thought it was odd that I had to search for them myself and was just wondering whether other users had similar troubles.
    By the way I am using Universal G-Code sender on Mac OSX.
    Thanks @GrayUK , I have tried emailing him but have had no reply, I have also posted in the xPro controller discussion, hopefully i'll get some info there.
    #1887 Jeremy Young, Dec 8, 2014
  28. John Meikrantz
    Getting close to completing my OX build. One more UPS delivery away...
    Shout out to Serge E for putting together the OX Calculator BOM spreadsheet! I couldn't have come this far without it. A huge time saver in keeping track of everything required as my design changed in size a few times, and I didn't wind up with too many extra parts.
    Serge E. and GrayUK like this.
  29. John Meikrantz
    My OX is complete! Basic testing done with motors and controller. Any ideas for wire management? I'm using xPRO CNC controller, but with an ATX power supply, so I don't think mounting to the x-axis crossbeam will work. Thinking maybe putting wire blocks on the x-axis to terminate everything, and then a single bundle of wire running from wire blocks to xPRO. Other option is of course to buy a 24v supply and mount everything to the x-axis.
  30. davidbrowne
    I've been reading about power supply ratings, and just want to point out that most off the stepper chips peak at about 2.5 amps max, so there's not much point in running above 12 amps, reguardless of voltage.
    My build is almost done, hoping to have it running over christmas break.
