OpenBuilds OX CNC Machine
  1. gibson
    gibson Well-Known
    its on .378
  2. gibson
    gibson Well-Known
    yes port 1
  3. gibson
    gibson Well-Known
    yes
  4. Jonny Norris
    Jonny Norris Well-Known
    Ok so in that case when you jog you should see steps on pin 2 and direction on pin 3,
    If you jog the x do you see the dro figures move?
    Sorry if I'm sounding patronising btw it's not intentional just helps to visualise what's going on
  5. gibson
    gibson Well-Known
    it oky your fine i get no movement of motors
  6. Jonny Norris
    If so put a multimeter over the Gnd terminal and pin 3 terminal, when you change direction you should see a voltage
  7. Jonny Norris
    The dro is the Xyza figures in the top right of Mach 3
  8. Jonny Norris
    the figures are the position so if they are not moving neither are you outputting any steps so need to confirm Mach 3 is outputting steps before continuing
  9. gibson
    gibson Well-Known
    oky motor runing
    X -MOTOR MOVED BUT JUST RUNS
    Jonny Norris likes this.
  10. Jonny Norris
    Brilliant, your almost there then. Most likely an active low unchecked. So what changed that made it run?
  11. gibson
    gibson Well-Known
    MOTOR LIKE MOVES SIDE TO SIDE LIKE ITS STUCK
  12. Jonny Norris
    No infact, it's well past my bed time, active low should make a difrence it shouldn't just run. Could you have your driver direction and steps wiring round the wrong way.
  13. Jonny Norris
    just vibrating and not moving? Two causes you have your motor poles wired wrong or too little current to drive the motor. It's only doing it when you jog tho yeah?
  14. Jonny Norris
    Two windings with both sides of the winding bridging both channels of your driver will make one winding try to go one way and the other the opposite way and cancel themselves out. I think, it's 3 in the morning I'm not sure of much right now but worth checking
  15. gibson
    gibson Well-Known
    YEA THEY ALL RUN BUT TRY TO MOVE ON STEP LOW
  16. Jonny Norris
    Oh and need to set your motor tuning, 400mm/min 50mm/ps/ps is a good place to start for x and y, half that for z
    Got to hit the sack, good luck. Sounds like your on your way. Takes an Intire week to set my machine up from scratch, calibrate and test it. And pretty much same with my ox. Have fun.
  17. gibson
    gibson Well-Known
    SAME HERE THANKS
  18. Jonny Norris
    Almost forgot, you need to do a steps per calculation, as default they are set real low and will make your motors go super slow especially with microstepping
  19. gibson
    gibson Well-Known
  20. Jonny Norris
    No that's for calculating feeds and speeds of cutting, search for steps per mm calculator.
  21. gibson
    gibson Well-Known
  22. gibson
    gibson Well-Known
    ResultResolution Teeth Step angleStepping Belt
    53.33 18.75micron 20 1.8° 1/16th 3mm
    This is what i got useing the gt3 belt on this site
  23. Jonny Norris
    Well if you enter that into motor tuning and then go to tools tab should see a button axis calibrate or setup or something similar in the bottom left corner, you can enter a dimension for it to travel, measure once travelled and enter that distance and see if it calculates a similar value, if it does I suggest you leave it with the original calculation over the Mach 3 calculation as it's usually more accurate
  24. gibson
    gibson Well-Known
    oky
    sir the x is going back and worth
  25. Jonny Norris
    Lol is it not supposed to?
  26. gibson
    gibson Well-Known
    oky i had the red and green wire on motor wrong so i switched them and now it move to the R and L but moves so far and stops
  27. gibson
    gibson Well-Known
    ? i have the ox buils with 4 motors can i hook the to Y ASIX UP TOGETHER
  28. gibson
    gibson Well-Known
    Oky i got every thang moveing
  29. gibson
    gibson Well-Known
    oky my X is only moveing in one direction any help
  30. Jonny Norris
    You're driver most likely isn't receiving the direction signal.
    Yes you can put both y and a (the other y driver) into one port on your bob, simply reverse the wiring of one of your y motors coils, ie choose a channel at the driver say b make pos neg and neg pos. so one motor turns the opposite way
