WIN a Free Smoothieboard! [CLOSED]
Discussion in '* CONTESTS * Win Cool Stuff!' started by MaryD, Mar 21, 2017.
Thread Status:
Not open for further replies.
  1. meebie11
    meebie11 New
    I'd use it for my next cbeam build.
    MaryD likes this.
  2. Aalte Zuidema
    I will use it to control my first self made , and still not began with , plasmacutter or lasercutter , wich i will show off here when it is finished
    MaryD likes this.
  3. lassivv
    lassivv New
    Want to get very good board on my prusa i2 heavy modifield printer.
    MaryD likes this.
  4. stephen cia
    stephen cia Well-Known
    working on my 3D printer crane style with IDEX (independent dual extrusion). At the moment it is working quite well with single extrusion. but the goal is to make this IDEX :) See below rendering done in Fusion 360 Double_X_Crane_v3.png Double_X_Crane_v2.png Double_X_Crane_v1.png
    MaryD likes this.
  5. jay_989
    jay_989 New
    Funds are tight so this would be super amazing but I'd use this for my new CNC router/laser cutter build :)
    MaryD likes this.
  6. GJO1605
    GJO1605 New
    I will use it in my first CNC machine that I'm building this year here in South Africa. It will be based on the C-Beam Sphinx XL running with 1.9Nm Nema 23 motors.
    MaryD likes this.
  7. Evgeniy
    Evgeniy New
    Laser cutter.
    MaryD likes this.
  8. boklu
    boklu New
    I use the Smoothieboard for a stardard I3 PrusaSteel. I had used Controller with Atmel 8bit Chip with has not the performance like the Smoothieboard.
    My first "Smoothieboard" was a "MKS sBase" with is very poor in quality! After 2-3 weeks of worke the MKS sBase burned out. Never again a sBase!
    The original Smoothieboard I used now works perfectly and very reliable!
    For my future projects (CoreXY-3D printer, CNC-Milling Machine, CNC Lasercutter) I will only use the original Smoothieboard!
    MaryD likes this.
  9. Gtidave
    Gtidave New
    I've been wanting to build a Laser Cutter!
    MaryD likes this.
  10. ParttimeRonin
    Still learning and collecting part design for D-bot Corexy remix, maybe with linear rail upgrade.
    And Smoothieboard definitely will go in that machine.
    MaryD likes this.
  11. Hakan_
    Hakan_ New
    I am planning on making a CNC router which will also be used as 3D Printer.
    MaryD likes this.
  12. Ales Vrabic
    On a home build Kossel XL 750
    MaryD likes this.
  13. Thanatos4
    Thanatos4 New
    I'm in the process of mapping out a CNC router build and winning the board will speed things up and will give me a good amount of breathing space as I'm on a student's budget.
    Alternatively I'd go for a high-end delta configuration in order to experiment with high speeds.
    MaryD likes this.
  14. bbmech7
    bbmech7 New
    I would put the Smoothie in my home build custom designed CNC gantry router. or in my large delta printer also home build custom designed.
    MaryD likes this.
  15. radmonius
    radmonius New
    I would like to build a CNC machine.
    MaryD likes this.
  16. David B
    David B New
    A modified Ooznest style Ox
    MaryD likes this.
  17. bmmal
    bmmal New
    small kids friendly 4 axis hot wire cutter
    MaryD likes this.
  18. Rob Taylor
    Seems a waste to get a 5 axis board and only use half of 'em. So... 5 axis mill, VMC style. The CAM is the limiting factor on those builds, but thanks to Fusion 360, it's reasonably doable.
    MaryD likes this.
  19. ShakyAxis
    ShakyAxis New
    I work as an MHE mechanic. I would like to build a three axis router with two axis accessory capabilities built completely from salvaged parts, including the linear motion. I will document the origin of all of the parts used. I would like a tight build with minimal deflection on a table size of approximately 2' by 4'. (600mm by 1200mm)
    MaryD likes this.
  20. Mike Mckenna
    Have built a delta. Well on m 3rd version of the delta. 1st was a very cheap kit from the east. The second was a Folger Tech kit (rev b). Now rebuilding from parts from both, but have added a real E3D V6 hotend and a Bltouch to the mix. Really like delta style, but the ramps is limited. Need a better board to run it.
    MaryD likes this.
  21. Willie
    Willie New
    I would like to use it to build a Laser cutter engraver
    MaryD likes this.
  22. Jonathan Shaw
    I would put it on the CoreXY printer that I'm working on because the math needed to handle the CoreXY motors would allow faster printing speeds than what RAMPS can currently supply.
    -os3dp
    MaryD likes this.
  23. ShadowFax
    ShadowFax New
    Instead of using it for single purpose machine, I would create a machine around the board that will use different heads/modules for different uses (3D printing, Laser Etching, Cutting, small CNC ...)
    MaryD likes this.
  24. Polymorph
    Polymorph New
    I am building a large Delta 3D printer with 1500mm rail travel and 330mm heated bed. It will have a 1mm hardened steel nozzle and use a modified bowden feed that keeps the filament feed motor weight off the head, but keeps the tube length down. I'd use the Smoothie board to drive it.
    MaryD likes this.
  25. Michael Biggio
    I am currently in the process of building a large format core XY 3d printer/laser Cutter/ CNC mill with swapable and modular heads. I would use it on this because of it's flexibility to be all three.
    MaryD likes this.
  26. Chris Chatelain
    Working on a coreXY right now that can do 13"x13"x13", a smoothieboard would be perfect!
    MaryD likes this.
  27. KSolomon
    KSolomon New
    I'm planning a D-Bot CoreXY build, so this would be the perfect brains for it!
    MaryD likes this.
  28. Charles B
    Charles B New
    Old Shapeoko 1. Would like a more updated control.
    MaryD likes this.
  29. Jan Hoekstra
    I would love to use it in my current build! I'm working on a OX Plasma cutter 2000x1000mm with plate marker.
    MaryD likes this.
  30. pixelnate
    pixelnate New
    I'd pair it with my modified Cobblebot Vanguard, built with v-slot and many Openbuilds parts.
    MaryD likes this.
Thread Status:
