Recent Activity
Activity stream for all registered members at OpenBuilds.
  1. David the swarfer liked Blacksmith74's post in the thread Limit Switches.
    This is a very stupid question and one that’s probably staring me in the face does the $ sign relate to the software, I keep seeing it...
    Jun 12, 2024 at 3:33 AM
  2. David the swarfer replied to the thread Blackbox X32 'opening the door' when powered off.
    so the wireless relay forgets to stay on when the power is off. Nothing strange there (-:
    Jun 12, 2024 at 3:32 AM
  3. David the swarfer replied to the thread Clarification of Fusion Pierce Height.
    set this as the offset from 'material top' in the top height setting in the heights tab. the surface of the material is Z=0. This is set...
    Jun 12, 2024 at 3:28 AM
  4. Mark Carew replied to a comment on {Project}
    Good point @Tadpole but I think this could be considered more of the symbol of the US flag and...
    Jun 11, 2024 at 7:39 PM
  5. JustinTime replied to the thread OpenBuilds CONTROL Software.
    I use both emergency switches. The one that only stops the program from running, the A0 to ground, and the one that cuts off the power...
    Jun 11, 2024 at 10:00 AM
  6. David the swarfer liked Peter Van Der Walt's post in the thread cant cut circles?.
    Grab the endmill, give it a firm wiggle. Follow sense of touch to find source of unwanted movement
    Jun 11, 2024 at 6:22 AM
  7. David the swarfer liked KEN MACDONALD's post in the thread SKETCHUCAM GENERATED GCODE HELP.
    Thank you David it’s working like a dream now
  8. KEN MACDONALD replied to the thread SKETCHUCAM GENERATED GCODE HELP.
    Jun 11, 2024 at 5:16 AM
  9. David the swarfer replied to the thread cant cut circles?.
    looks like backlash in Y , or some freaky spring loading against resistance. make sure your GRBL settings are correct, in particular $1...
    Jun 11, 2024 at 3:45 AM
  10. David the swarfer liked Giarc's post in the thread OpenBuilds CONTROL Software.
    If it is truly for an emergency, place the E-stop on the main power to your machine so if a true emergency happens, all power is cut. I...
    upload_2024-6-10_17-14-35.png upload_2024-6-10_17-18-7.png Jun 11, 2024 at 3:38 AM
  11. Giarc liked Rick 2.0's post in the thread Custom Acro Size ?.
    The wires should be long enough as they typically come in a stock length which you have to cut down. Something to verify with the shop...
    Jun 10, 2024 at 8:24 PM
  12. Giarc attached a file to the thread OpenBuilds CONTROL Software.
    upload_2024-6-10_17-14-35.png upload_2024-6-10_17-18-7.png Jun 10, 2024 at 8:20 PM
  13. Mark Carew liked Alex Chambers's post in the thread OpenBuilds just opened a brand new location!.
    YES! use this post processor :- docs:software:fusion360 [OpenBuilds Documentation] Alex.
    Jun 10, 2024 at 10:48 AM
  14. Rick 2.0 replied to the thread Custom Acro Size ?.
    Jun 10, 2024 at 10:37 AM
  15. David the swarfer replied to the thread Grbl Solid Handshaking.
    comments cannot contain anything but plain text (as stated in the Wiki) , and no embedded comments so (this is a comment (with a sub...
    Jun 10, 2024 at 3:25 AM
Loading...
