ooznest OX CNC Machine
Discussion in 'CNC Mills/Routers' started by Ryan Lock, Apr 28, 2015.
  1. kaffemannen
    Hi. Is the ooznest ox OK to use for PCB engraving?
  2. Ryan Lock
    Ryan Lock Veteran
    Solid Carbide you can't go wrong with really. Is it a V cutter you are after?
  3. Ryan Lock
    Ryan Lock Veteran
    Yes, should be able to, the important thing is to make sure it is well calibrated and tram.
  4. JohnC39
    JohnC39 New
    Hi Ryan, thanks for that. What sort of bits are good for engraving wood/acrylic?
    Will look into the other programmes you mentioned too.
    John
  5. JohnC39
    JohnC39 New
    Not sure what a V cutter is but I'll have a look.
    John
    Ryan Lock likes this.
  6. kaffemannen
    Hi Ryan, What tollerances can I expect to get on a 1500x1500 machine? Mainly for work in wood and plastic.
  7. Ryan Lock
    Ryan Lock Veteran
    0.2-0.25mm would be easily achievable on this machine.
  8. kaffemannen
    Thanks for the reply. But if the motor has 5% error on each step would that not sum up to more than 0.2?
  9. Giarc
    I am curious where you got the 5% error from. Or did I miss it in the discussion?
  10. kaffemannen
  11. Ryan Lock
    Ryan Lock Veteran
    The motors on the kit are NEMA23 1.8° +-5%. But the error is non accumulative on stepper motors. A full 1.8° step on these motors with GT3 Belts is 0.3mm of travel, so at 5% the error is +-0.015mm.
  12. Marcus1
    Marcus1 New
    Ryan
    Eventually found the cause...... It was the belt tension on the LH Y Axis.
    All seemed tight and good.
    The test was to force the RH Y axis and see how much it took to move. Do the same on the LH Side and it was easy and the belt was jumping out of the toothed wheel. All had looked fine.
    Would be good to have a strain gauge setting to tension the belts
    On the Vacuum tables.....
    I have created 3 Plenum Zones on the 1500x1500 bed, 2 off 500x1400mm, 1 off 300x1400. Each made of 3 5mm ply boards. Holes 2mm dia 10mm grid drilled in top sheet. The center piece is only around the edge and some spacers inbetween creating a honeycomb. Two inlets on each plenum Connected to one vacuum motor mounted under the machine. Plenum edges sealed with Gaffer tape. Spoilboard is 12mm Lite mdf in three pieces to suit the plenum, edges sealed with concrete drive sealer and gaffer tape, faced to remove top surface and level.
    Hold is great. using 300x300mm 9mm thick mdf on the top of the spoilboard, you cannot move the part. Have cut up to 75% of the surface of the 9mm board through and there is a large reduction in side to side holding, but it still holds small cut parts in place (using a 3mm up,down compression cutter). After using two corner supports screwed into the spoilboard the results are excellent.
    Lamb Amtek vacuum pumps were about £100 each - if you find better let me know
    Marcus
  13. Marcus1
    Marcus1 New
    John
    Really need to know what you are cutting - wood (hard/soft), man made (mdf), plastic, metal.
    Also are you engraving, Carving or cutting through?
    Marcus
  14. JohnC39
    JohnC39 New
    Hi Marcus,
    I will be cutting and engraving MDF and Acrylic.
    John
  15. Marcus1
    Marcus1 New
    I have experience with MDF not Acrylic
    For engraving MDF I use a 60 deg Vbit. Works great with the Vetric Software.
    If you are cutting a groove (not Through) use a Downcut spiral - This forces the swarf into the gap and gives a good top edge finish - Run at about 22000rpm and 3600mm/min. Any lower feed and you risk a fire!!!!
    For cutting through use a Up down Compression cutter. This gives a good edge on top and bottom. I use a 3mm Cutter for this, max depth 3mm per pass, same feeds and speeds as above.
    Marcus
    GrayUK likes this.
  16. JohnC39
    JohnC39 New
    H
    Hi Marcus,
    Thanks you very much for the info, will give me a good starting point once machine is up and running.
    It's just arrived so hopefully get it done over the weekend.
    John
  17. Marcus1
    Marcus1 New
    Get the 3mm Up Down spirals and 60 deg Cutter on ebay. Order the 3mm ones now as they come from China and take 3 weeks - come in packs of 5 or 6. Dead cheap (less than £20)
  18. Ryan Lock
    Ryan Lock Veteran
    @Marcus1 Great, thanks for letting us know, should help anyone out in the future. Also thanks for the info on the vacuum table :thumbsup:
  19. Giannis Papadopoulos
    Can you give me some information how you control the start and stop of the Kress Spindle.
    I am planning to bulit an 1500 X 1000 OX cnc machine but I prefer the Kress 1050 FME-1 spindle instead of Dewalt
    #619 Giannis Papadopoulos, Apr 29, 2017
  20. Giannis Papadopoulos
    Hi can you share with me the information about the vaccum table... Thanks in advance
  21. Marcus1
    Marcus1 New
    Previous stated
    GrayUK and Giannis Papadopoulos like this.
  22. Marcus1
    Marcus1 New
    Giannis
    I have a Chinese spindle 2.2KW running off a VFD Inverter. Speeds and on off controlled in Mach 3 through a suitable BOB
    Spindle uses ER20 Collet allowing up to 13mm
  23. Giannis Papadopoulos
    Driver
    I would like to use the Kress 1050 FME-1 spinlde, Can I use the ports from the CNC xPRO driver, Just for ON OFF of the spindle. It is manual adjustable, 6 speeds.
  24. Giannis Papadopoulos
    Sorry for my ignorance but can you give an example of pc-controlled mains switch
  25. Marcus1
    Marcus1 New
    I think Grantman means a RELAY
    Giannis Papadopoulos likes this.
  26. Giannis Papadopoulos
    A power relay I suppose or a softstarter ?
  27. JohnC39
    JohnC39 New
    Hi Guys,
    Well I finished the build of my CNC and just started the machine test and getting absolutely nothing??!!
    I have swung through the system and got 24v at the board, fans are running and 24v showing in the power unit.
    The firmware is set at 115200 and GRBL, says connected and all values were altered prior to connecting power.
    I put the meter on each motor and gave commands but seems nothing is going to the motors. I have also changed the pots to max and min but still nothing.
    The belts are aligned and tight so not really sure what to look for now so thought I'd better see if you guys have any ideas??
    John
  28. JohnC39
    JohnC39 New
    Hi Guys,
    False alarm just found a loose sheet with a manual change on value 4. All good!!!
    John
  29. JohnC39
    JohnC39 New
    Hi Guys,
    John
  30. Ryan Lock
    Ryan Lock Veteran
    Yes you can control a spindle with the xPro see here: CNC xPRO Driver
    I think you will need a relay as already mentioned.
